Electrical drain
Old 12-22-2006 | 08:43 AM
ramp7tab's Avatar
Default Electrical drain
Just replaced my alternator. Broke down on the road, dead battery but it is brand new. I suspect that I have an excessive electrical drain which caused this failure. Best method to solve this. I realize that after the car has shut down the draw on the battery should be around 40 milli amps, is this correct?
Old 12-22-2006 | 07:55 PM
Default RE: Electrical drain
If you are measuring Amps then it is a pretty long process.
You need to wait about 15 minutes it drops in stages till it reaches about .50 Amps.
If you replaced the Alt and it died after that than it sounds like it isn't charging.
RobertB
05-12-2015 05:50 PM
jbarnes
06-12-2013 12:46 PM
roughyear
02-10-2005 11:02 AM
x1sjwebster
02-09-2005 03:17 PM
PHLI72
12-14-2004 11:04 AM
