Electronic boost control or Increase turbo size
Hi All,
Now I would like to increase my Performance of my 2009 S80 2.5FT. There are 2 possible option: 1- install electronic boost control 2- change new turbo I had already shorten the wastegate actuator and I love the response of the car but I just need more Juice to just knock my head on the headrest. Any suggestion which should I go for? I am not sure if I install Boost control, will the ECU still be limiting my max boost? Cheers guys |
well theres polestar and they can give performance upgrades for your model (i think). Only be done @ dealer but its going to be expensive tho. give them a call
Hello Akabond
Thank you very mich for your advice. I've already upgraded my polestar rom. Apart from that i've already done these: Custom cat back Custom downpipe Heico spring Bilstien b8 shock Shorten wastegate actuator a little. So now i am looking for further Mod and possible mod next is these 2 things Either electronic boost controller or upsize the turbo. Or both. My local garage suggest using TDO4HL-18t So what do you guys think? |
