Engine Codes
If this has been listed before, I could-not find..If anyones knows when I may find engine codes for B6294T..2002 S80.T6..
Thanks very much |
RE: Engine Codes
What are you looking for how to pull the codes or a code list?
RE: Engine Codes
Code List, I have a OBD11 reader..Thanks
RE: Engine Codes
One more question if possibel...Is there a way to disarm the factory alarm and still be able to lock/unlock your car with the key..
On mine the alarm sets itself using the key to lock as well as the key fob...Mines a bit sensitive that a cat can walk under the car and set it off... |
RE: Engine Codes
Most likely the alarm is bad.
If you are looking for a P code list check out troublecodes.net |
RE: Engine Codes
Hey forum! Maybe someone can help me with this problem. For the last 6 mouth I have had this problem with my emission. I've been getting a emission light that keeps coming on. My mechanic said it some problem with my 5th cylinder. When the light come on my car it runs ruff. The plugs and coil packs have been changed OX's sensors have been changed also. THANKS GUYS
RE: Engine Codes
How about injectors?
