Engine Cooling Fan Staying on
OK so I got this 99 S80 2.9 and im having this problem that the cooling fan stays on at a full speed, it didnt do that before. i have to disconnect it because it drains the battery. I know it should work when your in a stop or turn on the A/C. Even with the car cool you connect the cooling fan and stays on at full speed. I know eventually this will damage the fan. What do you think the problem is?
Most likely the module on the cooling fan is bad. Sadly you need to replace the entire fan assembly to fix it.
I hit the module with a screw driver problem solved for now. the fan is working as it should. thank god.... that fan cost me used $130 2 months ago..
Originally Posted by gabyman97596
(Post 253563)
I "McGrubered" a stuck washer motor the same way on our V70 last weekend. Threw it on the ground, unstuck it, epoxied it and its good as new. Well maybe not new but meh. |
Originally Posted by NoLifeTilBoost
(Post 253656)
Epic win!
