Engine Emission Warning
Old Jul 30, 2006 | 02:26 AM
simon_mahoney's Avatar
Default Engine Emission Warning
About 18 months ago I had a service done by a private garage (non Volvo authorised) and the timing belt was changed.
Sometime since then I have been receiving an engine emission warning. No on permanently
The local volvo specialist (again private) seems to think the codes indicate a cam position problem ( and not the o2 sensors).
Could changing the timing belt have caused this problem.
How easy is it to a/ check the belt b/ reset the timing belt.
Old Jul 30, 2006 | 11:55 AM
Default RE: Engine Emission Warning
What codes were pulled?
Yes having the belt off by one or 2 teeth can set a code. But it would be a VVT code.
Then belt isn't all that hard to check. Remove the Top spark plug cover then the outer cover and you can inspect the belt.
Old Jul 30, 2006 | 05:08 PM
ramp's Avatar
The first time I replaced the belt on my wife's car, 2001 V70XC now 146,000, the cogged belt was off. By how many teeth I didn't know. I went in and moved the belt one tooth. Wrong! Went back and changed it two teeth in the other direction. Bingo
When the belt is off. idle is extremely erratic.
Good luck
Old Aug 1, 2006 | 12:00 AM
Coastal's Avatar
ORIGINAL: simon_mahoney
If the belt was done a year and a half ago, and you didn't see the ESS warning until MUCH later, then don't suspect the timing belt jumped. If the tensioner wasn't torqued correctly, you would have had camshaft position codes popping up rather quickly. You left off a letter in your statement, "No? on permanently" Was that for Now or Not?
Ah, does the shop not KNOW what the codes indicate? Have them relay the codes to you and post back.
I hope that I understand your facts as you've laid them out...
robingichuhi
Feb 22, 2017 04:34 PM
Callyandy
Aug 20, 2013 02:44 PM
AronS40
Jan 17, 2013 10:11 AM
slsnumber1
Feb 22, 2011 11:26 AM
jaz
May 3, 2006 01:02 AM
