Engine Swap/ ECM issues
I just recently put a S80 2.9l twin turbo motor in a v70 2.5l turbo, transmission and torque converter included. After putting everything back together i tried cranking the car and nothing. The dashboard lights come on but when I turn the key to start absolutely nothing happens. No click, no starter, no nothing. The error codes are as follows: P0700, P0798, P0763. Anybody have any ideas as to what the culprit might be? Thanks in advance!
I actually brought the ecm and tcm from the same engine I intend to use. It turned out that I had the wrong tcm in at the time. Then I found out that I had the wrong starter for the engine. They look the same. The correct starter is about 3/8" longer. So now that the engine is trying to turn over it sounds like someone dropped a screwdriver or something in the transmission and it's not cranking. I get a P0700 code now that I've erased the others. I'm swapping out the camshaft and crankshaft sensors to ones I know are from an S80. Thanks for your reply btw
a64armt
12-12-2017 03:12 PM
kevinpi
06-15-2015 05:38 PM
chasingvictory1989
03-31-2014 01:02 PM
