ENGINE SYSTEM SERVICE REQUIRED MSG
I have engine system service required message but no check engine light. Is there a way to clear it, or is there something wrong? I have held in the button on the end of the directional switch but it does not clear it.
RE: ENGINE SYSTEM SERVICE REQUIRED MSG
I found an old thread on this topic that worked.
Originally Posted by BILL_MCCASSEY
(Post 117933)
Try unplugging the battery for 15 min. That resets all the electronics including the engine light. This might work for you...
Reset "service required" message
I just cleared the service message on my Volvo C70 after changing the oil using this method. To reset the Volvo maintenance message without a fault code reader and aservice reset tool, do the following:
https://www.gunthervolvo.com/how-to-...vice-light.htm
(Post 117930)
Originally Posted by redelllib
(Post 514253)
An engine system service required message means there is a self diagnostic code stored in usually the ECM. To reset it requires reading the code with a scan tool and erasing it, the same as when the check engine light is on. |
| All times are GMT -5. The time now is 10:29 AM. |
