Error Code P1719
2009 S80 3.2
I am trying to help my senior neighbor with her car. The car cranks over with no issue but does not start. We replaced an old battery, just because ... and the car still will not start. Cranks fine. Her friend said he saw a P1719 error code and thinks it is a relay/sensor that is out causing the car to not start. Earlier, the car started and she put it in reverse. She got about 5 feet out and the car stopped and from that point would not start again. Any thoughts would be appreciated. Just trying to save her a few dollars ... Thanks! Craig |
Originally Posted by csomberg
(Post 466078)
2009 S80 3.2
what model/year? what codes are being shown? The P1719 is not a standard Volvo code so you may need to have a dealer do the scan with their VIDA tool. What I'd do is rent a high quality OBD2 scanner (ie Autozone) read the codes, write them down, then clear. Try to start the car and see what if any codes reset. Some people also suggest disconnecting the battery, waiting for 30+ minutes then reconnect but note that won't clear any codes.
Generally speaking that OBD code range is for transmission codes and if you have a no-start condition, it may be the shifter. Try doing a shifter row (Park to Lo to Park 10-20X times fast) to see if you can clean the PNP sensor contacts. It also may be caused by a communications issue between the ECU and TCU - so that may warrant cleaning the contacts on the TCU. |
Originally Posted by mt6127
(Post 484147)
Sounds like you need to get a dealer diagnostic scan as the generic definitions don't appear to apply to a Volvo. You may want to check some basics like fuses and relays if you haven't done so already.
(Post 484153)
thanks. I was just thinking I should have kept one of my project cars. Laying under a car is a great way to practice social distancing.
(Post 484173)
