fog lights??
has anyone tried putting on a pair of aftermarket fog lights on the first generation s80??
I heard that it is not as easy as it sounds.... |
RE: fog lights??
If you want to use the factory switch you will need software downloaded into the car.
RE: fog lights??
dang sounds like its pretty complicated....
what if i decided to use the switch provided with the kit?? would i still need to download the software?? |
RE: fog lights??
Aftermarket switch?
Oem wiring? If so then no but you would still have to figure the wires out from the back of the headlight switch. |
RE: fog lights??
Couldn't you just use a common ground and put a toggle switch hooked up to the battery direct..from an auto parts store on the dash somewhere..?
RE: fog lights??
Yes it can be done that way.
RE: fog lights??
oh maybe ill try that way
thank you so much guys :) |
