Garage remote
I just received delivery of a used 2009 S80. There are 3 buttons on the driver side visor, that I assume are for remotes. How do you program the garage remote. I do not know how to turn the car on to "accessory" as it is keyless and I'm clueless. Please help/
do you have the woners manual, if so it explains it quite easily...
If not, one of the guys with a newer s80 will have to tell you... But cant you still place your key into the dashboard slot (as a backup incase keyless fails) |
+1 to the owner's manual. If it is the homelink system then they have programming procedures on their website. Will need to use the rolling code procedure if your garage door has that option.
