Gear shift knob removal???
I want to replace the dried out and cracked gear shifter boot and have no idea how to remove it. At the bone yard I had to braek it off but upon inspection can find no easy way to R&R this part!
The knob just pulls off.
I had tried that at the bone yard and it pulled off but would not re attach
That is how I have changed all that I have.
We are still talking about just the knob correct? |
The automatic transmission lever in the console is the lever/handle
Are you wanting to remove the entire assembly after disconnecting the cable?
I just want to remove the handle assembly not the entire arm and linkage:(
1 Attachment(s)
Which setup do you have?
Maybe the diagrams will help you. Attachment 22350 http://img.photobucket.com/albums/v6...ifterboot1.jpg |
Thanks alot I pulled real FN hard and she poped right off, then once I finished the new boot she poped right back on
Glad all is good.
Thanks
Originally Posted by tech
(Post 182525)
We are still talking about just the knob correct? Thanks, Tech. it worked like a charm. I tried all the other methods on the Forums. So finally I said, OK, I'll pull it off and put both hands on it and knee on the seat, and yanked. And lo and behold, out it came. Lulumike |
Im having the same problem. I literally pulled until i almost passed out and it didnt pop off. Any solutions?
