Hard shudder right front
My 99 S80 T6 is now shuddering so hard on the right front when taking off from a stop, it shakes the dash. It does not do it when driving 40 MPH and up even if I floor it. Could it be the viscous coupling, and if so, how can I be sure?
Thanks, Bill |
Could be as simple as your engine mount!
Checked All mounts. They are good.
Thanks, Bill |
If you're sure about the mount by the right tire, then it maybe the bushings on your wishbone. When was the last time you had the suspension looked at?
I replaced the right lower control arm and axle 8 monthe ago. It was shuddering before that but not near as bad. I had a friend watch the wheel as I took off and he said it had a rotational jerking, not up and down or front to back. The front end is tight.
Thanks, Bill |
If you think it is the coupling, you should hear a few clicks sounds with your wheel turned and going in reverse slowly. But it may also be your tire/rim. The rim may be bent. Rotate the tire to the rear and test it. While you have the car up, grab your tire at the 12-6 postion and then the 3-9 position and wiggle the tire. Any movement may indicate a suspension component to be looked at.
The suspension and wheel bearing are tight. Rotated tires already to see if there would be a change. Tires have been road forced and wheels are not bent. When backing up with the wheel turned, how noticable will the clicking be?
Thanks, Bill |
Do you know if it's possible to remove the axle and viscous coupling, and install an axle for an S80 without viscous coupling?
