having trouble with oil filter cover
had my exhaust fix over the week end and tech told me that my oil filter is leaking.
I found a 86mm 16 flute socket for the oil filter cover but it does not work,it keeps slipping on cover,do i have the right size. 2003 s80=t6\2.9 |
Get a big pair of Channel Lock pliers
Originally Posted by thommykent
(Post 453569)
It can be done and you have no choice. Or get a really good removal tool made of cast aluminum.Sheet metal or plastic ones will not work if it`s on that tight as you found out.
well I had my oil changed and it still leaks bad dont know were it is coming from.
any body have trouble with the front seal leaking. |
