Head gasket set
Have a 2006 S80 2.5T. Pretty sure i have the B5254T2 engine. Had the timing belt brake and have now having the cylinder head redone.Need some help on buying a head gasket set for it. See lots of them for sell. Rockauto has 4 selections from Felpro, Victor. Not sure what to buy. Any help on this would be greatly appreciated.
the engine type is on a sticker on the timing cover and is stamped into the block on the firewall side of #1 to be sure. Google "volvo modular engine wiki" to be sure but assuming you engine has never been swapped, there's also a two digit code in the VIN (position 6-7) is yours 59 (a 5254T2) or a 68 (5254T3)?
https://www.ipdusa.com/products/2075...0637066-139378 shows there is a VIN serial number break that you may need to consider. Also check to see what FCP Euro sells. IPD and FCP are my two Volvo friendly go to stores... |
Thanks for the information. My vin position number is 59. Will check out these stores out. Want to keep this S80 rolling. Really like this car.
