Headlight
After driving on the freeway today, my headlight cracked because of a rock. There is a big hole in the lens and it spider webbed on me. Has anyone changed the headlight piece, or the lense it self. what problems did you encouter, did you remove the grill, or the bumper. any other things had to be removed? where can i get a headlight that will fit perfectly, or should i just get it from the dealer, any past experience with this guys? help me out please
RE: Headlight
I have heard of alot of people buying the Glass off of E-bay.
You will have to remove or loosen the front bumper and slide it out to get the Headlight out. |
RE: Headlight
My headlight filled with some water lol, what do i do, It freezes at night and Melts during the day.....(too cold to evaporate)
It happened a few days ago, The Errors message comes up, bulb position out of place....... but the headlights work fine... Is there a crack or soemthing in my headlight? |
RE: Headlight
Usually condensation means Air leak.
RE: Headlight
haha ... i cant seem to find it...>< lol
RE: Headlight
You won't if the gasket between the glass and housing is cracked air will get in there as well.
Not to sure what to tell you because you have to remove/loosen the front bumper to get the light out. |
RE: Headlight
Have you seen these things covered under warranty?-for the reason you just told me
RE: Headlight
Factory warranty yes.
Extended no but it would be worth it to ask. |
RE: Headlight
Does it matter the coverage type i got? I have comprehensive coverage :)
RE: Headlight
Im not sure you would have to call them and see if it is covered.
RE: Headlight
If the headlight is still working why does the error message come up for it? is it kno that there is water in my headlight lol? shuts off after a minute or so..
RE: Headlight
Not sure maybe bad connection.
