-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   headlight removal (https://volvoforums.com/forum/volvo-s80-18/headlight-removal-29362/)
volvos8087 Apr 9, 2009 02:14 PM
headlight removal
i would like to know how to remove my headlight fixtures on my 2000 volvo s80. if anyone can help thanks alot.
diplomat128 Apr 10, 2009 10:54 PM
I just finished doing it like 10 times just today (re-doing my retrofit)
First you gotta remove your bumper
1- open the hood and where the grill is there is like 10 black pins you can pull out, DO IT!
2- on the bottom of the bumper in the bottom grille opening, on each side there is a little tab you can pull out, there is 1 on each side, pull them out and there will be a screw, unscrew it.
3- Remove the wipers somehow, I don't remember how I did it tho. But remove them. And then pull out on that black plastic trim that goes along the bumper where the orange corner light is
4- once you unscrew both sides, SLIDE the bumper outwards towards the front of the car
5- once the bumper is off there is 2 screws over the headlights on each side, un screw them
6- un plug all the wiring.
volvos8087 Apr 11, 2009 01:11 PM
yeah its not that easy because there are quite a bit of pop rivets on the bumper inside the wheel well that i found out were holding it on also.
