JTapper |
02-24-2009 07:53 PM |
Lose the low beams only? If you checked the fuse in the passenger compartment, AND the two under the hood, and they're all good it is probably the resistor shunt on the CEM. It's under the dash on the drivers side, left side of the footwell. The low beam one is the bottom one. It's about 1 1/4" wide by 3/16" thick blade looking deal with 4 prongs. Swap that one out with one of the ones above it (for turn signals). They're all the same. If you get lights, then you need to replace the bad shunt. They're available from the dealer for around $6. I believe it's part #9442190
