Headliner Repair
The headliner on the left and right support beams (i.e the supports running from the dashboard to the interior roof) is coming undone. Is there a way to remove these panels so that the felt material can be reglued to them?
RE: Headliner Repair
They are held in with plastic clips and a spring.
If you pull carefully at the top by the Headliner it should pop loose. |
Thanks, I'll give it try.
