Help: 2008 S80 "Blind spot syst. Service required" is there a diagnosis procedure?
Old 04-02-2018, 10:32 AM
bans25's Avatar
Default Help: 2008 S80 "Blind spot syst. Service required" is there a diagnosis procedure?
Hi all,
I have a 2008 S80 T6 that is giving a "Blind spot syst. Service required" message all the time. I cleaned the cameras (and the mirror camera's are getting warm). Is there a procedure to diagnose what may be wrong? Any common issues with this system that mine may be experiencing?
I searched around but have not been able to find anything. Any help is appreciated.
thanks much.
Old 04-02-2018, 04:21 PM
tony1963's Avatar
You are going to have to have someone pull the codes. My guess is that you have a communications fault.
Old 04-02-2018, 05:02 PM
bans25's Avatar
What type of scanner is needed? Is this something only a dealer can scan? I am new to Volvos. Thanks much!
Old 04-05-2018, 08:46 PM
ES6T's Avatar
Take it to the dealer. Diagnosis for any warning light is free.
Old 04-09-2018, 12:08 PM
bans25's Avatar
Wow, I had no idea the dealer would read the codes for free.. I was thinking Volvo would be like every other "stealership" I have dealt with in the past!
Old 04-21-2018, 02:34 PM
bans25's Avatar
I was able to use a scanner today that can read the codes.
B118C04
B118E00
any ideas what may be setting the codes?
Old 04-21-2018, 02:59 PM
bans25's Avatar
I just figured out B118E00 was that my drives side “auto up/down” needed to reset (it wasn’t working), once I reset I am down to 1 code: B118C04
any help diagnosing this is appreciated!
Thanks all!
jtdb153
02-10-2017 01:17 PM
Miga
08-25-2016 03:08 AM
don in denver
06-09-2014 09:54 AM
JBxc60
12-05-2013 08:57 AM
chrissygm
09-30-2008 05:53 PM
Quick Reply: Help: 2008 S80 "Blind spot syst. Service required" is there a diagnosis procedure?
