Help: 2008 S80 "Blind spot syst. Service required" is there a diagnosis procedure?
Hi all,
I have a 2008 S80 T6 that is giving a "Blind spot syst. Service required" message all the time. I cleaned the cameras (and the mirror camera's are getting warm). Is there a procedure to diagnose what may be wrong? Any common issues with this system that mine may be experiencing? I searched around but have not been able to find anything. Any help is appreciated. thanks much. |
You are going to have to have someone pull the codes. My guess is that you have a communications fault.
What type of scanner is needed? Is this something only a dealer can scan? I am new to Volvos. Thanks much! |
Take it to the dealer. Diagnosis for any warning light is free.
Originally Posted by ES6T
(Post 458448)
I was able to use a scanner today that can read the codes. B118C04 B118E00 any ideas what may be setting the codes? |
I just figured out B118E00 was that my drives side “auto up/down” needed to reset (it wasn’t working), once I reset I am down to 1 code: B118C04 any help diagnosing this is appreciated! Thanks all! |
