Help!
Old Oct 14, 2016 | 08:53 PM
01volvos80's Avatar
Angry Help!
Anyone else experience their volvo at idle bogging up and down between 400-1000 rpms and sometimes its so rough it will actually shut off? I experience this when my car has warmed up and its becoming very frustrating
Old Oct 18, 2016 | 08:48 AM
naperboiler's Avatar
I ran into a similar issue with a very unexpected stall. A full PCV service (expensive hose included) got rid of the problem.
Old Oct 18, 2016 | 07:32 PM
could be a few things - engine coolant temp sensor comes to mind as well as a stuck idle air valve (not sure if your model even has one...) as well as other vacuum and intake leak problems.
You can do a simple test for the PCV / oil trap - with the engine running, pull out the dipstick. See any smoke coming out?. Next test is to remove the oil fill cap and put a rubber (ie surgeon's ) glove over the oil fill. If it inflates while the car idles, you are not venting the crank case and should repair before you blow out your cam seals etc.
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
