Help.... My sunroof is stuck open!!!
Hello everyone,
Well I made the mistake of opening my sunroof , My alarm module is bad and I should've known better than to open the sunroof. So, yes now the sunroof is open and won't go back down (it's in vent position) . Tried everything I think! Any help with this matter would be greatly appreciated. |
I'm surprised that it worked at all with a bad alarm module. However, the only thing that I can think of is to disconnect the battery for 5 min and try again.
Sunroof finally went down
Originally Posted by tony1963
(Post 460215)
I'm guessing that there isn't a way , but anyway like I said it finally went down. The sunroof works from time to time , I should know better than to use the it but it was getting warm out and didn't want to use the a/c . I will eventually pick up a used siren and try to get the alarm system working again , geez these cars can be touchy . |
did you ever get this closed?
There should be a screw on the side of the little...regulator motor? Not sure what it's called. but it does have a little screw that is turnable. |
