HELP! Please - Hydraulic Shift Solenoid (New Transmission?)
I have a 2000 S80 T-6 that I bought in August, 1999. I have coddled this car - doing every service required and some. She has less than 90K miles (I think around 88 - and the first 75K was mostly highway miles). Yesterday, it seemed a little bit weird - was skipping gears, struggling to get up a hill. I started to drive it to my local dealership when the URGENT Service Transmission Soon light came on.
The dealer says I have an internal fault - the hydraulic shift solenoid is bad - and therefore have to replace the WHOLE transmission. They told me it would cost $4900. I just had the transmission serviced and flushed in July. ANY advice you can give me would be great help. I am (was?) a Volvo for Life owner. My first was a 1986 240 DL and I was gearing up to buy my third next year. I called Volvo and they said they don't know of any issues with our transmissions, but the forums here tell me otherwise. |
RE: HELP! Please - Hydraulic Shift Solenoid (New Transmission?)
Did they give you a copy of the codes they pulled?
A solenoid can be replaced. Volvo won't do it but it can be done. |
The 99-01 S80 GMtransmissions are known to have problems. They are garbage in my opinion. I had to have my transmission replaced at a cost of $3500 plus tax at a volvo dealer at 114k miles back in the summer of 07. $4900 is way to much. Is that including tax or no. I had mine replaced at the dealer in Columbus Ohio.
I just e-mailed them asking for the Codes, and will post as soon as I have them.
The $4900 is parts, labor and tax. The independent Volvo mechanic I spoke with also told me that the part cannot be fixed or replaced and I needed to get a new transmission. My car is only worth $6500 and this is just traumatising - financially, and emotionally (I love my Volvo!) Thanks for the replies. Will update as soon as I have the Codes, etc. |
Thanks once again for the replies. This is what the Volvo dealership told me the codes were:
It pulled a code TCM-000c=Shift solenoid s2 hydraulic fault. |
That solenoid should be able to be replaced.
It is kind of a pain but I believe it can be replaced. I will look for the part# as well but it might take me till tomorrow to get it. |
Tomorrow is okay. I have arranged with the dealership to keep the car there until tomorrow afternoon. Thanks so much for all the help and suggestions.
Is there a site I can find recommended shops and/or mechanics? Two Volvo dealerships (one in Southern California - very large and reputable - and one a little further North) told me that I had to get a new transmission. An independent Volvo mechanic in Southern California also told me the same. So not sure who can do this job for me! Thanks - once again - for all the help and suggestions. |
Sowhat's the difference between a remanufactured or a rebuilt or a used transmission. I am getting more and more confused every day. AndI amstuck in a rental car until I get this fixed.
I guess there isno such thing as a "new" transmission. |
A rebuild and a reman are pretty much the same exact thing.
I will have the other info shortly. |
9480636 should be the part number you need. But to be 100% sure I would need the last 6 of your Vin#.
The transmission will have to be dropped down most of the way and the side cover will have to be removed to install it. I had posted the instructions on here before but cannot find them. |
get it rebuilt from Aamco I just got mine its running solid and shifting like no tommorow :)...
Thank you for your help. I picked it up from the dealership and took it to a transmission shop. He said the part is replaceable. I am greatful to all of you - especially you 'tech' for all your help.
Glad I could help you out.
OK slowing down in the motor way, while car slowing down transmission slams on me and then reduced power with traction control light on and CEL , took to service center I get TCM 0115 error code Transmission Solenoid S Hydraulic fault. Service guy is not VOLVO so cant say what parts i need... I hope you know what it is Tech?
