-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   How do you delete a text message? (https://volvoforums.com/forum/volvo-s80-18/how-do-you-delete-text-message-546/)
tfolkner Oct 3, 2004 03:53 PM
I have a 2003 S80T6. It is over a year old. I want to delete a text message and cannot see in the manual how to delete the message. The message is
"On Call Plus Deactivated". This also causes the warning light /!\ to come on.
Is there any way of deleting the annoying message?
Also there is a leak of power steering fluid. I can't find it, but the reservoir needs refilling once every month. Has anyone had a similar problem?
Thanks for your help,
Troy Folkner
tech Oct 3, 2004 07:08 PM
RE: How do you delete a text message?
I will check on the message for you.As far as the leak check the hoses at the reservoir they are prone to leak there also check at the pump.If not there also check the metal lines at the steering rack the bolts on some of them weren't torqued properly causing them to leak.check those places and let me know.
jlw253@yahoo.com Jun 18, 2005 08:19 PM
Did anyone ever answer this one (re: how to turn off the on-call message.) I just purchased a 2004 T6 and am having the same problem. It's really annoying.
reg Jun 18, 2005 11:10 PM
I had a power steering leak also. I and the dealer could not find the leak....................the dealer changed every hose and etc. Finally the pump was changed and voila..............no more leak!! So...............ask the dealer to change the pump and perhaps your problem will be solved.
TitaniumGreyS60 Mar 6, 2008 03:40 PM
Wow no answers in years Holy crap.
I have the same problem....
Looks like I have to go elsewhere!
JPN Mar 6, 2008 11:29 PM
Moved from New Members Area. Due to its age I did not notify the original poster.
This post has been dug up after years, but the forum has changed with great members and I believe someone would be able to answer this question. I moved this to General Volvo Chat rather than the S80 forum, as moremembers can take a look at it.
JPN
1999S80T6 Mar 7, 2008 12:12 AM
ORIGINAL: TitaniumGreyS60
Look no further buddy... you are at the right forum. I will bet you can find solution for your problem in this forum.
Good luck.
