Installing an amp in a S80
Not sure if I should post this here. Has anyone installed a amp and sub in conjuction with the stock radio (HU801) and had very good results????? Also read were there was a equalizer hidden in the S80's, how do you get to it??
RE: Installing an amp in a S80
this is fairly easy...I have a 2001 s80 t6....
1st - fold down the rear seats. 2nd-remove all the carpeting 3rd- near the rear seats on the left and right sides there shud be a set of wires held together on each side. Look for 2 gray wires(those were wrapped with a bunch of orange wires, and they are the only two gray ones there) , those shud be your speaker wire. take two wires, splice into them. so there shud be one wires coming off of one of the gray wires. do the same to the other side. connect it to the box which converts the wires into rca. 4th-ground the amp, ull see two bolts just behind the folded seats, use those to ground the amp. Hook the power into it 5th- there shud be a remote base controll, when u open ur trunk to the left shud be another set of wires.. Have to find the speaker wire and splice into that, 6th-hook everythin up, and u shud be good to goo! check my setup. http://www.cardomain.com/ride/2188838 |
ORIGINAL: gordon368 this is fairly easy...I have a 2001 s80 t6.... 1st - fold down the rear seats. 2nd-remove all the carpeting 3rd- near the rear seats on the left and right sides there shud be a set of wires held together on each side. Look for 2 gray wires(those were wrapped with a bunch of orange wires, and they are the only two gray ones there) , those shud be your speaker wire. take two wires, splice into them. so there shud be one wires coming off of one of the gray wires. do the same to the other side. connect it to the box which converts the wires into rca. 4th-ground the amp, ull see two bolts just behind the folded seats, use those to ground the amp. Hook the power into it 5th- there shud be a remote base controll, when u open ur trunk to the left shud be another set of wires.. Have to find the speaker wire and splice into that, 6th-hook everythin up, and u shud be good to goo! check my setup. http://www.cardomain.com/ride/2188838 Did you ever get the SRS straightened out? |
yes i did, new srs module and new middle seatbelt.....
HAD nothing TO DO WITH THE AUDIO SYSTEM!!!!!!!!!!!!!!!!!!!!!!!! |
CONGRATS!!!! Thank god WARRANTY?????????
lol it was so covered under the warranty, my car was with them for like 2 and a half weeks, drop off was: 12/29, pick up was: 01/12. I also put in EDEAD which elimated all of the rattles cause by my 500 watt 10 inch jl w7!
Cool!!!
Thank god My 12's don't rattle that much. If I only Had a Cap. Then I wouldn't almost kill the battery everytime I drove!! LOL |
Is there a remote wire in that bunch or one I could use? I basically ran the power straight from the battery in the trunk. Is there any where else I can run the wire from in the trunk area? I was thinking maybe an antenna connection
