interior light
the light bulb for climate control knob went out on my 99 s80
does anyone know how i would be able to take it out and replace the bulb?? |
RE: interior light
REMOVE BATTERY TERMINAL AND APPLIED PARKING BRAKEOR INSTALL WHEEL BLOCK BEFORE ANY WORK DONE! SRS LIGHT MAY COME ON WHEN U PULL CONNECTOR OFF OF CLIMATE CONTROL WHEN IF BATTERY IS PLUGGED IN!
1.) remove gear shifter surround (may need to shif gear shifter out of park by turning into key position#1) 2.) remove 2 torx 25 screws at lower climate control panel 3.) shove a plastic wedge or bone tool in between the center point of the radio and climate control (so that there is a gap between radio and climate control) 4.)install a 90 degree hook or a pick behind the climate control casing "IN BLACK" (2 dimple 1 left and 1 on right) "DO NOT HOOK ON TO PANEL FACE SINCE IT CAN CRACK OR SCRATCH THE FACE OF CLIMATE CONTROL PANEL!" 5.) disconnect climate control's connector in the back of the unit (if climate cotnrol is in odd angle and in your way shift gear shifter out of park) 6.) remove bulbs by using a small flat head screw driver (if possible remove all so that it don't have to get done again on other bulbs) 7.) reinstall connectors behind climate contro panel 8.) lined up hook on top or climate control and push unit strait in "NOT AT AN ANGLE" 9.) reinstall 2 screws on bottom of climate unit. 10.) reinstall shifter surround and re-install battery 11.) re-adjust clock Here is a picture of the bone tool: http://www.ipdusa.com/Volvo-V70XC70-...-127-731-2542/ |
RE: interior light
dam~ thanks a lot for the fast reply :)
| All times are GMT -5. The time now is 01:46 AM. |
