-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   Jacking points on S80 (https://volvoforums.com/forum/volvo-s80-18/jacking-points-s80-29414/)
nicolaselias Apr 11, 2009 04:43 PM
I don't normally do much of the work on my car for myself but I wanted to begin with some basics.. Considering that Jacking the car correctly is absolutely essential, I wanted to make sure I knew what I was doing before I did.
Using a standard rolling floor jack, where would I want to jack the car from (front) and where will I want to put the jack stands. Any tips to make it easier/safer?
I understand that the car weighs about 3700lbs, so I am assuming a 2ton jack will be fine, but I wanted to double check that with you all.
Thanks
JTapper Apr 11, 2009 08:56 PM
I jack at the factory jacking point, and put jackstands at the front and rear subframe mounts.
75ohm Apr 12, 2009 07:52 PM
+1....
