Key Fob Case
Where in the world can I find a key fob case a 2004 S80? 5 button w/ a flip key. It is working fine, but he case is falling apart.
check ebay. there's a couple on there for $15
does anybody know how to reprogram those keys?
Don't think you can. I know for the earlier fobs you need the pin code that comes with them. Also there's information saying once they've been programmed for a cAR they can't be reprogrammed even with the pin. The actual key itself can be cut by anyone but must be coded to the car by the dealer.
I fix Volvo switchblade keys. Also referred to as a volvo flip key. When the broken key will not extend or retract, I replace the inner workings. Repair parts are unavailable through Volvo and a replacement key is very expensive. Key replacement and reprogramming is expensive. The "chip", embedded within, is matched to your car. A replacement or used key with a different "chip", won't work. It won't start your car! The key (chip) itself can't be "reprogrammed"! I can save you the hundreds of dollars that the dealer route would cost. Your key will be restored to original factory operation, with your original "chip" within, at a small fraction of the cost. 24 hour turnaround with priority mail. Professionally done. Guaranteed.
Contact Tony at amp1117@yahoo.com |
