Leaking Power Steering
My 2000 S-80 is leaking power steering fluid. I can't see where the leak is coming from when looking under the hood. Could it be that my pump is leaking or is a hose? It's only leaking on the passenger side. What do I need to do to find out what's leaking and fix the problem.
Thanks! |
Do you see any oilish residue around the pump/hose? If so, one is leaking, first check to ensure the clamp is secure and inspect the hose (run your fingers along it and squish a little to see if you can produce a leak. If nothing, clean the residue of the hose/pump and watch it the next few days and see if you can pinpoint the leak further.
If you do not see any residue/leakage from the pump/hose, it could be your power steering rack leaking. |
Will Check, I can't seem to see anything from the top, there's a bit of residue around the reservoir, I'm doing my best to keep oil in it, but I do notice when it's low it make some noise only when I turn the wheel left. Thanks for the advice!
could the the boots/seals = rebuild, sorry
