LOUD '09 S80 Power Steering - Help with other ideas
Old 09-23-2018, 04:22 PM
Confluencetrader's Avatar
Default LOUD '09 S80 Power Steering - Solved!!
Hi. New to the forum. We are on our second s80 and have had a good experience with our first. Currently, we own an '09 S80 and it developed a loud power steering groan when turning and just sitting idle. The mechanic put in a new pump, but that did not stop the noise. $575 later. There are no obvious leaks anywhere, as I was thinking it might be the rack and pinion leaking, but that seems unlikely given there is no fluid anywhere to be seen. Any other thoughts would be appreciated!
Last edited by Confluencetrader; 10-03-2018 at 02:55 PM. Reason: Wanted to say my problem was solved and how to do it.
Old 09-30-2018, 01:59 PM
p_gill's Avatar
My first post on this forum
I have been thinking about buying a S80 for my son.
i have a 2008 Land Rover LR2 with the same powertrain as the S80 3.2 AWD
The power steering should be the same for both
as for the answers to your question the power steering reservoir has a filter screen in the bottom and the screen gets clogged and then the pump gets loud
Note: the fluid should be replaced as well, it does’t last forever
take a look at this link
Freel2.com - View topic - Noisey steering pumps?
Here is the video from the link
it’s not my video
the pentosin fluid that is specified isn’t red as shown in the video
i use CHF 202 (you can buy it from Volvo also)
good luck
Paul
Old 10-02-2018, 10:36 AM
I ordered the reservoir and fluid and will give that a try.
Old 10-03-2018, 02:53 PM
I ordered a reservoir from Parts Geek for $32 and the fluid from them as well for $16. I installed the reservoir today and the car sounds like new! Very easy to do. Suck out the fluid from the reservoir, remove one hose clamp and a pinch fitting at the bottom of the reservoir; put in the new one in reverse order and fill to max with the fluid. I turned on the car and spun the steering wheel back and forth 20 times to get the fluid worked in and the air out. That was it!
Old 10-04-2018, 05:09 PM
p_gill's Avatar
Trader,
That's excellent news!!!!!
On to the next task
Have you thought about replacing your Thermostat?
Failures have been reported at about 10 years
Some information about replacing the Thermostat
Freel2.com - View topic - 3.2 Thermostat replacement
See the link below for more information about common issue with older I6 3.2 (note: this is for AWD if you have FWD then you can skip some of these)
For reference you just completed
9. Power steering fluid and reservoir replaced due to noisy heavy steering
And I am recommending that you look into
8. Thermostat - replaced mine at 10 years (also replaced two coolant hoses)
The list is mine but as you can see from my post I collected the information from other posters and I haven't done all of the items on the list
https://www.matthewsvolvosite.com/fo...p?f=31&t=86205
Good Luck
Paul
MSGTUSMC
11-04-2016 10:24 AM
pcgold
12-21-2009 01:25 PM
tmixdorf
08-31-2009 08:25 PM
placervillebob
04-15-2009 11:48 AM
goldwagon
05-19-2007 12:02 PM
Quick Reply: LOUD '09 S80 Power Steering - Help with other ideas
