Lowbeams come on at random
My lowbeams will just come on at random times of the day. I could be driving and they will come on. I go to leave for lunch and they are on. I check my car out when i get out to make sure everything is off and the lights arent on and when I go back they are on. Think it could be the fuse? I also have problems with the key when I put it in the ignition it won't turn then after a few tries it will turn.
Has the vehicle ever been in any water damage situation?
Or have you put in an after market stereo? Once I had an aftermarket stereo installed in a 97' Volvo, and after that all sorts of problems occured similar to your issues. I took it back to the shop (which was an amature shop) and made them tinker around until it was better, But other strange electrical problems started cropping up after that a bit later too. If you recently had anything done like that, you should probably take it back to the shop. Just an idea... |
To clarify, are your lamps coming on when you are driving/car running or even when the car is off?
Most S80s have Daytime Running Lights enabled, so your low beams should be on at all times (regardless of switch position - with the exception of parking lights only) when you are driving. My guess is the switch is failing or something is tripping it up. |
My 2004 has an aftermarket stereo and does not have any problems like that?
Originally Posted by zacharyzoosh
(Post 260173)
jlewis- Yes sometimes the light will come on when i'm driving. Now I get out of the car check the lights to make sure they are off and then I go back and the low beams are on.
Zachary- I bought the car used so I dont know if it had water damage and no aftermarket stereo. I've had nothing done to it. |
