-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   my 2002 s80 t6 project, rebuilding motor (https://volvoforums.com/forum/volvo-s80-18/my-2002-s80-t6-project-rebuilding-motor-15260/)
my93vr4 11-20-2007 09:39 PM
rebuilding my motor heres pics, new piston rings , stem seal valves, water pump, idle pulley,tensioner pulley,14 head bolts, head gasket, timing belt, gaskets, and clean all motor inside from sludge cost me everything under $1,000 hope to be done with in 2 weeks its my project after work.
[IMG]local://upfiles/13513/6A22C75901AF4AB09AE861B5A56A4435.jpg[/IMG]
[IMG]local://upfiles/13513/4254AE3B97E94793908AD309D8BAAF7D.jpg[/IMG]
tech 11-20-2007 09:56 PM
RE: my 2002 s80 t6 project, rebuilding motor
Nice pics keep them coming.
Also make sure you check your turbo's really good.
Make sure they are good.
my93vr4 11-21-2007 04:32 PM
heres few more pics
ramp 11-24-2007 03:14 PM
Wow!!
[align=left] [/align]
tripleb 11-24-2007 09:54 PM
It sure looks like you have more than one engine torn apart!
Did you blow the head gasket?
Just curious why you would do a complete tear down.
Were the rings bad?
B
my93vr4 11-25-2007 12:28 PM
i did this because previos owner did not change oil on time and used cheap oil,engine have alot of sludgeinside and cooked oil that cloged small holes inside motor, valve stemseals went bad and 2 turbos ,,i'm changing piston ring because i'm already there ,nothink wrong with piston rings just wana changethem, car have 101,000 miles on it. in all turbo cars i recomend to use' fully synthetic oil' and change your oil on time,if you want your turbos to last , turbos for s80 are very expencive if you gona get them new... synthetic iol alot cheaper then turbos,or you will change your turbosalot sooner if you use regular oil, thats my thinking.feel free to add your coment
tripleb 11-25-2007 02:15 PM
I've seen good results with a good non-synthetic as long as the oil and filter are chenged every 3k. We used to see a bunch of lease return cars in this condition, even before out of warranty.
Good Luck with the engine.
B
my93vr4 11-28-2007 09:08 PM
heres 2 more pics
tech 11-29-2007 05:58 PM
Wow that was really sludged.
Almost the worse I have seen.
I have only seen one worse than that.
sophisticars 01-21-2008 06:32 AM
Is it all back together and running like a new one?
