My Volvo revs up and down
They funny thing is that i got my volvo recently and was asking everyone about the reliability of the car car and now it revs up and down at idle.
The car drives fine no engine codes but at idle it revs up and down. I almost wants to stall than revs up what could this and how much will it run me any help is appriciated |
RE: My Volvo revs up and down
First will be throttle cleaning.
Next will be waiting for codes to come then take it to the Dealer and Hopefully it is throttle body codes and they wil download Software for Free. |
I agree with "tech", it sounds like the fuel system. A full fuel system flush would take care of the injectors.
Hey Tech, what about high end? My surges just barely enough to notice, but seems ok on cruise control. I notice it most when driving around 60, on flat smooth roads. Then it surges up then down, only about 100 rpm difference. But being a commercial pilot. I notice little changes like this. Maybe I am going crasy and expect to much.
JC |
The surge could be your foot. On cruise, there isnt a chance of accidental depression of the gas pedal causing a higher rev. With your foot on the pedal, every little bump will cause a slight change. The thing with S80's is the gas is very sensitive past about 50 degrees. (the angle, not the temperature.) Once depressed, the gas can be very reactive. At high speeds, unless its a T6 or a souped up S80, slight depression will not cause noticeable acceleration, but just a difference in RPM's.
They also Act Very funny with a Dirty thottle body.
Thanks everyone.. One more question. Sorry, just trying to learn the car.
When I punch it, power comes on strong, then at about 3200, surges down a bit, then around 4000 picks back up. It's not a solid pull like my other cars, but they are not turbo. Is this normal, the turbos just speeding up to catch up? I known in the Crossfire Merc compressor, the power increases steady until maxed. Reminds me of flying a jet. You hit the power, get a huge surge, starts moving, then when the speed catches up to the power, slows down a bit, then kicks you in the butt. Thanks again. Just want to make sure nothing is wrong. JC |
The throttle body issue could be causing it as well. But not really normal.
My car did the exact same thing. I took it in for the FREE software update and it's fine now. You should have gotten a recall letter about software service update
Tech when you say clean the throttle body, what do you mean? I know the ETM/ECM are connected right, or is the ETM all by itself? To clean it I guess you mean take it apart, off the intake manifold and "clean" why?
Thanks.. |
Yes the ETM is seperate from the ECM
Yes you need to remove it and clean all the Carbon out of it. The carbon messes with the computer. |
Originally Posted by jerryman
(Post 28188)
When I punch it, power comes on strong, then at about 3200, surges down a bit, then around 4000 picks back up. It's not a solid pull like my other cars, but they are not turbo. Is this normal, the turbos just speeding up to catch up? I known in the Crossfire Merc compressor, the power increases steady until maxed. Reminds me of flying a jet. You hit the power, get a huge surge, starts moving, then when the speed catches up to the power, slows down a bit, then kicks you in the butt. Thanks again. Just want to make sure nothing is wrong. JC Thanks!! |
Also looking for an update- sounds like this is the same problem I am facing
Doing more research. Especially if you have a Turbo Volvo. PCV valves can get plugged. This is one thing that could be causing the issue.
As to why if you own a Turbo it is so important to change oil, and do all maintenance regularly. Just so many issues that can arise with Turbos. |
