need to clean throttle body???(video)
akabond, I don't think so throttle body cleaning requires, if yours car acceleration is OK and does not fluctuate the RPM then surly not. I am smelling some electrical issue.
What's going on? Do you have a CEL or other error message? |
Originally Posted by majorcode
(Post 376805)
For now lets start with easy stuff :) |
Originally Posted by rspi
(Post 376818)
You may want to give some written description of your problem. I thought that you posted a video of how to clean a throttle body.
What's going on? Do you have a CEL or other error message? As for the messages well i have none..no check engine light, no error message. nothing. the only thing i have on is new PCV breather hose. But the bad start up was there before i changed installed the new pcv hose. |
akabond, though not a bad idea to change to PCV timely but just remembered the same thing i been facing and upon diagnosed my crankshaft seals found leaked and after replacing never faced such issue. Nothing wrong to check them as well. Good Luck! Do update what comes out :)
good point..but can you show me with picture where to find crankshaft seals so i can check the condition. i would love to have a inspect.
also i did ask the service tech (who works in garage) at volvo dealership. since i met him at a volvo meet. he quote me around $1,300 or $1,500. it includes : -timing belt kit change -PCV change and throttle body clean -fuel filter change above will cost $1,300 if i want to do cam seals too then total will be $1,500 i think from a dealer not a bad deal for the things that will be done. what yall think |
Hi, this link will gives you the complete details.
http://www.matthewsvolvosite.com/for...p?f=11&t=56244 However I suggest simply check the seals condition, if it is ok then you can wait anther 5K Miles, since you are already crossed 100K, soon your car is up for timing belt change and there will be another overhead, so if the seals are already leaked then you have to do the whole job (Timing belt change, pulley, oil pump seal etc) |
