Is it normal for bad ABS wheel speed sensor to show wear marks?
After scanning my ABS system , and found a code for the front drivers side
wheel speed sensor , I decided to pull the sensor to inspect.... After removing the sensor it was obvious that it was bad just by the sight of it ,(I should've taken a picture of it) My question is , is it normal for the sensor to have this much wear? I own a 04 Volvo S80 T6 Premier DSTC option as well if that matter's I ordered a new one and don't want to break a new one if I'm missing something... any help on this matter would be appreciated ... Thank You. |
Replaced ABS speed sensor ....
2 Attachment(s)
Well I guess everything is in working order ,guessing that there was
a wheel bearing issue at one time, because everything feels tight and secure when I tried to check for play ,, here is the pic of the old sensor (must be original )Attachment 13756 Attachment 13757 |
