Oil cap seal
Changed plugs and found some oil on top of engine. nothing bad none in plug wells. looks like it may be from the oil cap area. Anyone no how to replace the oil cap seal?
http://www.ipdusa.com/Volvo-S80-P2/E...-576-589-5163/
Also check your crank case pressure before it gets too high. May be time to do the PCV System. |
How do you check crank case pressure and what should it be?
