oil drain plug size
I have a 200 s80 non-turbo. What size wrench do you need to remove the oil drain plug? is there a special key you need to use?
thanks nertil |
RE: oil drain plug size
volvos range from 12 to 13 to 15 and back to 14 and 17 and 18.. i mean..just get a set of wrenches and see which one fits.. i did an engine swap on a 1996 960.. used about every single socket and wrench i had...lol..
Usually it is a 17mm on these cars. But I have seen many 18mm and 19mm when someone replaces them.
