Oil Pan O-Rings
Hello Tech
I am not sure if my Oil Pan O-Rings are bad... I have no pressure warning, no leaks from the oil pan. just a small leak from the OIL TRAP. like a spray... is not a big leak. the problem is that the car does a ticking noise (like a valves noise) when pulling and only when the engine is warm. it doesn't happen all the time... VOLVO Dealer in the UK say they have no idea what the noise can be. and they have never done any Oil Pan O-Ring replacement. they have checked some sensors to stop the engine pinking or something and they are ok. how can i make sure the Oil Pan O-Rings are bad? Many Thanks Regards |
You will have to have the oil pressure checked.
Hello
I will
Thanks |
