-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   Oxygen Sensor, sensor 1 bank 2 (https://volvoforums.com/forum/volvo-s80-18/oxygen-sensor-sensor-1-bank-2-a-8802/)
soduku007 Nov 23, 2006 09:43 AM
Hi,
My 99 S80 has a check engine light (CEL) that indicates the oxygen sensor (sensor 1, bank2) went bad. Which one is sensor 1 bank 2? I was told the sensor 1 is the one before catalyst, but I don't know which side is bank 2.
The air filter and vacuum hoses are still pretty good and also cleaned up the mass air flow sensor with a CRC electronic cleaner. But, I still have CEL. I am going to look at spark plugs to find out engine combustion. Do you guys have any suggestions before replacing a new oxygen sensor? I think an oxygen sensor is pretty reliable, and often the CEL was caused by something else.
Can anybody post the oxygen sensor location and replacement procedures from VADIS? Thanks in advance.
tech Nov 24, 2006 11:55 AM
RE: Oxygen Sensor, sensor 1 bank 2
Front O2 bank 2 is the front one on the drivers side.
Bank 1 is cylinders 1-2-3
Bank 2 is cylinder s 4-5-6
soduku007 Nov 25, 2006 11:11 PM
Thanks, Tech. I replaced all new spark plugs today, and didn't get CEL for the first two drivings. I thought I fixed this CEL issue, but the CEL came back for the third driving. Hence, I think I need to replace the front oxygen sensor (sensor 1) for the driver side (Bank 2). The oxygen sensor costs around $200, but I got about $500 estimation for this oxygen sensor job from a local dealer. My questions are
1) How difficult to replace the oxygen sensor? I did timing belt change, idler pulley, serpentine belt all by myself. I think I can loan oxygen sensor tools from an Autozone.
2) Anybody can give me time estimation to complete this job by using regular 2.5 ton jacks ? Please post procedures to replace the oxygen sensor if you can. Thanks in advance.
tech Nov 26, 2006 12:31 AM
The sensor is ok to do.
Will take some time though. You might have to drop the exhaust to get to it.
Other than that it is easy to do once the exhaust is down.
soduku007 Nov 27, 2006 09:27 PM
Thanks, Tech. I called a local independent Volvo shop to replace the bank 2 oxygen sensor 1. I got $415 quote($220 for part) from the shop, but only replacing the bank 2 oxgen sensor 1 without any diagnostics. They said they usually charge $95 for check-ups. In addition, I need to wait two days for my appointment.
Hence, I simply drove to a local Volvo dealer, and I was told $101 for check-up the CEL (there will be no check-up charge if I repair it there). There was also Vovlo ETM software upgrade recall. So, I signed up for the Check Engine Light (CEL) check up. There was no charge for the recalled ETM software upgrade. In fact, I got the Service Light Warning for last several months. I think I don't have to replace the expensive oxygen sensor if I paid an attention to the Service Light Warning signal. I simply neglected it. As you know, improper Air/Fuel mixture by ETM software can contaminate oxygen sensors.
I was told the bank 2 oxygen sensor 1 was bad exactly like the Autozone OBD II code reading. The total oxygen sensor repair cost was $432 ($260 for oxygen sensor and gasket). The ETM software upgrade may resolve the CEL issue. Anyway, I am happy now since I don't see the CEL anymore. Thanks.
tech Nov 27, 2006 10:20 PM
Congrats.
Keep an eye on the light.
It might have been from the old software but I doubt it.
Pumina Nov 20, 2013 05:52 PM
Due to the age of your vehicle, I would recommend changing all sensors. The parts are not that expensive but the labour is pretty high considering the exhaust needs to come down.
I am not an expert but had a similar problem in my S80 2000 and this is what was recommended by Volvo as once one sensor develops a fault, others compensate and thus get weak.
Best of luck.
537playing Nov 20, 2013 08:10 PM
I replaced all four of my sensors and never had to remove the exhaust. It's challenging but better than playing with exhaust bolts!
_val Nov 21, 2013 09:32 AM
I got both right side oxygen sensors from Bosch for about 190usd total.
I couldn't change sensors while exhaust was attached to car.
I think this can be done in 2-3 hours by non mechanic if you have the right tools.
http://content29-foto.inbox.lv/album...3137.sized.jpg
difflock54 Nov 21, 2013 06:25 PM
One would think they could have designed the system to mount all the sensors at the sides,facing out to enable simple access from beneath with a suitable jack or vehicle hoist.
alam Feb 5, 2016 12:09 PM
Can you share your technique for doing this? Thanks!
Joan George Milton Sep 28, 2017 12:21 AM
02 sensor replacement
I have a 1998 Volvo 70 station wagon, car is in great shape but I need the sensor replaced for inspection and was told that the exhaust will have to be dropped down. I already have the new sensor, will this be an expensive job? Thanks
ramar Oct 26, 2017 10:15 AM
i also have a 1998 volvo v70. replaced cap, rotor, plugs, wires and the car ran good for a few days. now it runs ruff at 70 mph, the CEL came on and autozone said code P0171 indicates bank 1 system is too lean for a predetermined period of time.
the print out also indicated that ASE technicians have seen this issue your time of vehicle and the most likely solution is faulty vacuum hoses. the store guy thought i might need an O2 sensor. i know the vacuum line broke a few months ago. now i need to replace the vacuum lines. now the engine will not turn over. i charged the battery and nothing but bright dash lights. i will check the elec connection of the thin wire to the terminal on the starter. i think there is a ground strap between the body and the chassis or between the engine and the chassis or somewhere that often fails. does anyone know about this or it's location?
ramar Oct 26, 2017 10:17 AM
i will try hammering the starter solenoid too.
Oodlemi Oct 26, 2017 10:48 AM
I'd suggest starting a new thread ramar.
Greg Steels Oct 7, 2019 12:38 PM
Volvo
Hi I have a 1998 Volvo V70 and need to change my front and back o2 sensor's
mt6127 Oct 7, 2019 04:01 PM
What is your question about changing the O2 sensors?
For some background, the main thing is the front and rear sensors have two different jobs on the I5 engines - the front does the "lambda" control for the fuel mixture, the rear monitors the catalytic converters efficiency by allowing the ECU to compare the oxygen levels before and after the cat. If you are getting a check engine light code (or more than one), then you need to research possible causes. Generally you shouldn't need to change both O2 sensors at the same time but if you are replacing the cat or doing work on the downpipe or flex pipe then its a good time to stick a new part in.
