marc sanders |
02-22-2014 05:59 PM |
P0036 and P0136
2000 S80 T6. P0036 and 136 codes (bank 1, sensor 2). Replaced both downstream O2 sensors with Bosch units. Still throws codes. Disconnected battery for 10 minutes, still throws codes. Idle is rough. Hesitates on acceleration. Cleaned MAF sensor. It has aftermarket plugs and a few aftermarket coils. No evident vacuum leaks. I have the voltage measurements from the scanner. They are identical on both banks, but I am not sure how to interpret them. The rich-ln and ln-rich thresholds are both 0.605 V. The min V for cycle show max 0.595, the min is 0 and the measured is 0.190. The max V for cycle shows max 1.075, min 0.615 and measured 0.720. Any suggestions? Thanks for the help!
