P0237 Turbo boost sensor A circuit low
need your help guys
car drives fine, check engine light went on and then off the next day, mech scanned and came up with that (guess its stored in memory)
Car had some surging idle, now its steady, but i think i feel some surging still...
what should i do ?
what should i do ?
for those who are searching this thread like years after i posted this - yes the boost sensor was the culprit, so if you are sitting at a red light and all the sudden your rpm dips down once or twice, or if you are getting a jerky pedal reaction upon acceleration accompanied with slight vibration along with the code P0237 then yes - this is the sensor to change for sure, car feels like new now, got all my power back, lots of torque, i go up hills at 1500 - 1700 rpm @ 80 Km/h. i think the sensor can be cleaned, cause after i took it out and saw the little hole that can easily plug up with dirt and oil its kinda obvious, i think this has been happening for a while and i have always felt some slight rpm dips and jerkiness that is now gone...
James Johnson (05-08-2021)
its ok you cant get to them all, it was frustrating , but i think its all good now
the part is about $135 canadian + tax at the dealer, i tried searching like 6 different websites and noone of them had it in stock,
i got a discount atthe dealer cause the guy was nice, i got it for 110 + tax, online i think its about 80-100 canadian
the sensor is in an easy location to change but it still gave me trouble at the plastic clips that hold it are so friggin tight it took me almost an hour to change, but at least i did no need a mechanics ;-)
interesting enough I have to do this one bymyself, What exactly has to be removed in order to access the area I need to get too?
Will this roughly take an hour to do? Basic tools needed?
is that a fair price on the part for it, if so I will go ahead and buy it:
http://www.autopartsworld.com/volvo_...nsor/2001.html
Thanks
Thanks
thats a damn good price for a bosch oem part for a volvo, i paid more than that
once you get your hands in there you will see what needs to be removed, its just a little hose that needs to be put aside
you will need a long flat screwdriver, or two, and i would use some kind of thin (not latex or nitrile) gloves like rubber dipped for better grip,,,
other than that, good luck and dont break the tabs that gold the sensor!!!
shocking how easy this is to get too, I tried to clean it with carb cleaner, it didnt work. So I ordered the new sensor.
also found a used sensor for 24$? would any suggest that this be okay?
http://cgi.ebay.com/ebaymotors/Volvo...Q5fAccessories
#20
