Passenger side view mirror cracked
Does anyone know if I will be able to replace a shattered side view mirror, without having to purchase an entire new side view mirror assembly? Only the mirror is cracked. Is it possible to purchase just the mirror and clamp it on? It is a 2001 S80 T.
Thank you. |
It looks like the make it as a seperate part number:
http://www.trademotion.com/partlocat...layCatalogid=0 So that is a good sign that you should be able to order it right from Volvo. I would guess, $60 or so dollars (I think that is how much my Lincoln's was to replace with the heated mirror element). |
side view mirror reply
thank you for your reply. it was very kind of you. i actually found that website when I googled for side view mirrors. just was not sure if i would be able to just replace the mirror part, or if it would require replacing entire assembly. hopefully, i will be able to just snap on a new one....best to you.
passenger mirror replacement
NBender....
I just ordered this exact part...wife hit it on the garage on the way out. It was $86.47, factory new...try this guy, Joe @ ebayparts@volvo-oc.com I have ordered many parts from him...from headlights to cup holders... The old one "peels" off, if you have heated mirrors be careful as there are 2 plugs on the back side...the mirror has the female connection on the backside if I remember correctly...you'll want to pull it off slowly. the new one will go right back in place... Good luck. |
Cheap way out is to buy a piece of mirrored Plexiglas (plastic) and cut one yourself to fit. Use RTV (Permatex- engine gasket maker) on back to hold in place.
Also works well when the rear view mirror inside the car goes. |
Just replaced mine last night with the one I ordered from the guy I recommended...was very easy. pushed the mirror all the way "in" and the plastic frame popped right off and after a light messing with, the other popped right back on...pretty easy...there is an answer on fixya.com to help with a little more detail on the "how to" portion of this post...good luck
I have a driver's side one, heated, I bought used by mistake on eBay. If anyone needs it, let me know. I would have to look to see what it cost me but I don't think it was more than $25 w/o shipping.
My year 2005 has a different shape and is $80 new at the dealership. |
Does anyone know if the 2005 has the same 'feature' of extracting the old mirror as the 1999-2003? I haven't replaced either and they are both scratched now.
i had it on my Lexus ..it was cracked so i just bought a glass and pasted it over. But the thing was now the dimmer wont be as efficient. but it was sooo cheaper
Originally Posted by akabond
(Post 248217)
Originally Posted by jlewisinsyr
(Post 248253)
Why bother having a nice car when you're just going to fix it like this?
