Play in Front wheel
Recently I have been having clunking in the front right end of my S80. After replacing the struts, strunt mounts, bushings, swayba links, ball joint and tie rod ends I still have it
This morning I was looking at it and grabbed the front tire pulled in and out only find movement, about a 1/2 inch at the top of the tire. When replacing the ball joint I had the control arm out and the mounts were fine. Struts are nice and tight too. What could this be? Thanks Chris |
RE: Play in Front wheel
Was it from up and down or side to side?
Possible tie rod? |
