pole star 19 inch wheels on 2015 s80
Hi guys , I really need help
My 2015 s8 T6 has 4C chassis, currently im running 18 inch wheels came with it, now I want to have 19 inch polestar wheel!.
My main concern is acceleration and ride quality, other concerns is car height change (ground clearance).
Please help and thank u in advance
Assuming you have the correct offset, center hub and bolt pattern with the 19 inch wheels and run the correct tire size then you will not change the acceleration or ride height. If your current tire size is the 245/40-18s, then the plus one size would be 245/35-19 on an 8.5Jx19 ET50 rim. Ride quality will be somewhat firmer as your new wheels will have shorter, stiffer sideways but given you're already running 40s, your already pretty firm.
