Position Light?
A message has come up on my screen that reads "Bulb Failure - Position Light"
Does anyone know what that refers to? |
RE: Position Light?
Rear Parking lights.
RE: Position Light?
So I will only see a light bulb out when the car is in reverse?
RE: Position Light?
At the bottom of each taillight assembly there are two lamps toward the outboard side of the assembly. These are your position lamps & one of them is either loose or burnt out.
Take a look with the car running and you should be able to spot the one that's out; again, there are two on each side, and they're red (clear lamps, red lens). You do not have to be in reverse...they're on all the time. Been there....Previous Position Lamp thread |
