Radiator Advice
2 Attachment(s)
Guys, please view the pictures...seems my radiator is linking. Though its not too much, but I am worried if it gets worst. Please advice either to
1: put any additive 2: Just replace part attached to radiator 3: Complete radiator. 4: Just put silicon can works And how it is easy if I try to change my self. Will appreciate your advices. Thanks Volvo s80 1999 2.9 |
mine is leaking in the same spot and then one more on the other side, best to just replace it, i tried that radiator patch crap, didn't work at all... :/
Just replace it. The additives are a waste.
Lor3nzod: Did you replace the whole radiator because so far I know this leaking part lose silicon because of heat, it may need replace if broken or just by opening and fixing again with silicon.
If replaced, which one you used after market or genuine ...please recommend. |
I haven't replaced mine yet but it is getting worse, it started out very small but now i'm filling my reservoir every 3-4 days.. Going to have plans changing it out with OEM part from volvo.
