Radiator Water On Driver Floor Matt
I have leake at driver side floor matt, Its from Radiator green water.
any one have similer problem? how much it cost to fix? what is the problem? cheers |
RE: Radiator Water On Driver Floor Matt
Sounds like heater core needs to be replaced. I have never replaced one on a foreign car, however they are bout $50 on an american car.
I think on the S80 the Dash has to come out to replace it.
Yes it sounds like the Heater core is leaking. |
Thanx guys, it sound bad. do u think if i u use stop leake lliquid that will help? or does it effect on the water cooling system?
thanx |
I would not use the Stop leak. But that is just me. It is designed to Clog things. It might clog other things as well.
ORIGINAL: lmrs80 Sounds like heater core needs to be replaced. I have never replaced one on a foreign car, however they are bout $50 on an american car. Jon |
you can try ebay. I've seen some random s80 parts on there. Do not use leak stop. Yes it may stop it now, but most of those chemicals just dump a thick sludge like material ini there that tries to fill in the cracks and crevaces (spelling?). In the end that stuff will be stuck in there and make a mess internally.
