Random Multiple Misfire, Fuel Trim System Too Lean, Cylinder 5 & 6 Misfire
When I try to crank the car it will take long or will not crank until I try it again. It works sometimes when I tap the gas pedal a few times. I get a reduced engine performance if it takes long to start up. These are the only major problems I have with the car. 138,000 miles on it. Volvo S80 2002 2.9L
did you get it fixed ?
Originally Posted by divinedavis
(Post 390866)
http://www.snowblowerforum.com/forum...es/welcome.gif to the forum jaydownsouth
Have you tried to swap coils from 5&6 with any of the other four to see if the misfire moves ?? Have you inspected the plugs and if so how did they look ?? Any chance you have something causing a vac leak to those cylinders ?? |
Tried it
(Post 427603)
