Rearview Mirror 02 S80 T6
My reearview mirror has a seatbelt light and autodim feature that is not working. I don't see any buttons on the mirror to turn it on nor is the mirror getting any power. Is there a fuse I could check for this or is it going to be a wiring problem.
RE: Rearview Mirror 02 S80 T6
I forget if there is a fuse for it or not.
The Mirror is actually a computer. Does the central locking work? Does the remotes work? Does the sunroof work? Try locking and unlocking the car with the key and see if it works then. |
The unlock and lock works both in car and with keyless entry. And the sunroof works as well....
Then it might be a fault from the Mirror.
If those functions work the Mirror has power to it. You might want to have the Dealer pull codes. |
When you say pull codes....does that pertain to any warning lights? Such as check engine or service soon lights? Cause I have no warning lights of any kind.
The rear veiw mirror is not connected to any lights but the system holds codes.
The proper name for the Mirror module is a Upper Electronic Module. |
I popped my Fusebox open and it was missing two Fuses, replaced them both and now it works. Thanks for the info Tech!
which fuses did u replace? my mirror isn't working either
