S 80 Mass electrical problems
Hi Everyone...hope someone can help. We've had various problems with our 2000 T6 S 80. The most recent (all within seconds): brake failure warning then a/c quit, windows wouldn't work, headlights failed to come on (running lights worked) turn lights failed to work (flashers worked) and doors wouldnt lock/unlock with the remote. Radio worked.
I checked every fuse and moved the relays (ones in fuse panels) around and nothing seemed to help. then all of a sudden all works??? Going to name this car Christine. Also service air bags message has been on as well as service ABS brakes, both for months. Any ideas? |
"Going to name this car Christine."
^^ that came ouf of nowhere i did have a problem with door locks, it would lock but not unlock, stayed like that for a few days then started working again. same with a few noises and check engine light, my advise with these cars is - if it aint broken dont touch it |
Charging system working ok?
Christine (in case anyones under 50) was a possessed car.
thanks for the replys....charging system seems to be o.k. but I'll look into it further. If the battery goes dead or even a low voltage can really mess things up.
Car should be charging atleast 14.0 to 14.25 volts.
